My laundry machine doesn't work properly in my new flat (the wash cycle never ends), and the instructions specify that the common cause of my problem is that the drain is too low (my drain is indeed at 15" above the machine bottom, whereas the instructions recommend 30").
I'm quite curious as to why this is the case; common sense dictates that too low a drain shouldn't be an issue, doesn't it?
Does somebody have an explanation for this requirement?
  • I believe that height helps ensure against sewage being siphoned back into the machine. – keshlam Apr 30 '16 at 18:02
  • Respectfully, there is a trap, a "J bend" in the wall, that serves that purpose. Also the inherent bend the drain pipe of the washing machine has, allows water to set in it as well. The drain pipe connection to the wall is not a sealed fit, so the J bend in the wall does the task of sealing out the sewer fumes. – Jack Apr 30 '16 at 18:29
  • Having the drain arch at least that high keeps a leaky valve from emptying the whole washing machine. – Daniel Griscom Apr 30 '16 at 21:30
    Actually, I'm not sure there's even a valve on the drain of most machines; there may just be a pump that is either on or off. When off, the water is retained by the height of the water column left in the drain (which should arch higher than the water level in the tub). – Daniel Griscom Apr 30 '16 at 22:38
  • ... Ah. I was right about syphon risk, misremembered the direction. @Jack has it right. – keshlam May 1 '16 at 2:36
13
The water in the wash tub will drain out if the drain in the wall is lower than the water level in the washing machine. Simple physics, water seeks its own level. The drain located at the recommended height will allow the water to remain and allow the pump to remove the water at the end of the cycle.
| improve this answer | |
  • That's right. I imagine that the cycle never completes as it's always trying to fill up to the required level. – handyman May 3 '16 at 19:05
