So, I recently purchased a new house and went about changing the locks. The doorknob worked well, but not so much on the deadbolt. Installed everything but one screw which wouldn't budge. I ended up stripping it, but was able to remove it. Since it was the same model as the old deadbolt, I figure the screws on the old one would work. I ended up jamming the screw and now even a stripped screw extractor bit can't move it. Any help would be appreciated.
    Can you post a photo so we can tell which screw is giving you a problem?
    – mikes
    Apr 30, 2016 at 1:17
    Sometimes, drilling/grinding the head off is the best option available...
    – keshlam
    Apr 30, 2016 at 3:20
  • 4
    A dremel with a cut off disk can cut a slot that a straight blade screwdriver may be able to back it out.
    Apr 30, 2016 at 9:48
You can try drilling the head of the screw, which will allow you to remove the cover of th lock and use a vise grip to un-tighten the old screw. Good Luck
