I have a built-in wardrobe without internal panels. I am planning to add some panels in it.
I bought 18 mm furniture panels with melamine coated.
How can I attach a horizontal panel to a vertical panel (T-Joint) ?
Should I used some wood plugs ?
Sign up to join this communityThe usual method is to use a jig to drill rows of holes,
then use plastic clips that press into the holes and support the shelf.
There are many variations, including metal versions, some including holes for screws.
You could use dowels but that would look slightly less neat perhaps.
