1 Answer
Scratches that are not all the way through the surface you can polish out, or sand out and leave a matte surface that will not show scratches so easily.
Chips can, at best, be filled with something that never quite matches, or you replace the table-top, as it's the only actual fix for those, IMPE. The canonical product that never quite matches is called "Seam-fil" evidently.
The simplest effective solution is called a tablecloth.
+1 for "The simplest effective solution is called a tablecloth".– Michael Karas ♦Apr 25, 2016 at 5:17
Thanks guys. What do I use for polishing. Tablecloth does not really work for a coffee table– MiniMeApr 25, 2016 at 14:59
