I have a ceiling fixture in the kitchen that I like and can't find a replacement electronic ballast (Tospo TP120-1/26UPL 26W). A replacement fixture has been hard to find and stupid expensive. I realized many of the newer LED ceiling lights are basically just LED tapes.
Since I was going to also run RGB LED tape throughout the kitchen, I thought it might be nice to also control the overhead light. Could run the tape in a square spiral - should give off more light than what was there before. Most of the LED tapes I've seen on Amazon though have a power supply / transformer.
Do they make ones that don't need a transformer?
And if so, what would that be called?
The CFL bulb that was in the fixture would get plenty hot, guessing I shouldn't have to worry about heat off the LEDs but also interesting in any opinions here too.
