This question already has an answer here:
I don't know much about electricity.
In my kitchen there are 3 GFCI receptacles. There was a kettle plugged into one and the microwave. The fridge was on the other. Both outlets quit last night when I opened the fridge, but the breaker didn't trip.
The reset buttons won't do anything, the green light at the bottom of the receptacle is off (on these GFCIs the light is on when they have power).
Every other outlet on this circuit is working, including the other GFCIs.
Any ideas what happened here?
Should I replace the GFCI outlets?
marked as duplicate by Mazura, Chris Cudmore, Niall C. May 2 '16 at 14:06
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • Were you using the microwave and/or kettle at the time? Did you press the reset button in far enough? Are you sure that the dead GFCIs are on the same circuit as the other receptacles? It's not clear from the question exactly what was plugged in where, and which GFCIs won't reset. Can you clarify? What size is the breaker that's feeding the receptacle? – Tester101 Apr 22 '16 at 2:57
  • If it will not reset that is a classic symptom if it not receiving power. Start tracing from the breaker box to make sure it isn't a bad breaker. If it is the wiring you will want professional assistance. – SDsolar May 13 '17 at 1:08
Try unplugging your appliances and see if you can get the GFCIs to reset.
From there, if you can't get them to reset, possibly one of them is defective.
If the GFCIs do reset, possibly one of the appliances is broken.
Good luck!
  • I tried unplugging the appliances and the GFI would not reset. I guess I'll try replacing to see if they're defective. – Andrew S Apr 22 '16 at 2:05
