The inspector suggested that these are easy fixes but most of the searches for repairing window sills brings up rotten wood and that's not what I've got here.
and also this one
Sign up to join this communityI find that a urethane caulk works wonders in cases like this. It bonds like no other caulk I've used, can be had in a huge variety of custom colors, doesn't shrink much, remains very flexible, and is paintable. I'm most familiar with OSI Quad.
Be warned, it's extremely sticky--you won't get it off your clothes, and you'll have to wear it off your skin. It cures very slowly, so don't expect it to be skinned over after a few minutes like silicone or latex.
Cut a small opening on the tube and press firmly to inject the caulk deeply into the crack. Use cardboard or a plastic scraper to remove any excess, pressing very firmly to slice the extra caulk off the surface rather than smearing it wide. Ideally you'll be able to apply and tool the caulk in one pass with the tube nozzle, though.
Backfill with fixall in the deeper spots and smooth over with a epoxy sealer. Or, do the whole thing with dex-o-tex.. stuff is magic i think you could fix my 40 year soured marriage with it.
Polyurethane caulking works but you will find that sometimes you see that through paint.
