My wife and I rent a duplex in an old neighborhood of Honolulu, HI. We have talked about mounting our 55" XBR-55X810C Sony 4K TV since we bought it, and yesterday we bought a mount on a whim. It's a Stanley tilting mount for 32" up to 70" TV's up to 90 pounds in weight. The XBR-55X810C specs say it's 38.2 pounds. Here is a link to the mount: http://www.stanleymounts.com/tlr-es2215t-product-page.html
But unfortunately, everything made sense after a wasted trip to the HW store to buy a $15.99 stud finder, and that was, the walls are thin pieces of wood paneling without studs the tilting mount instructions call for. Umm, probably should have added that up when we realized the electrical sockets throughout most of the electrical outlets are facing sideways on the baseboards, and the light switches have electrical running on the outside of the wall into the ceiling (pictures attached).
The wall is located between our LR and MBR; and there is no view to see what's inside, checked the breaker and ground, but there is a ceiling crawl space in the bathroom I can can look.
To measure the thickness I measured the inside of the door jam (3 4/16"), and subtracted the measurement of each outside edge of the jam to the wood paneling to the wood paneling on both sides, subtracting the outside doorjam overhang on each side and taking it away from the initial measure (inside measurement - (1 11/16" + 12/16") 2 7/16" = 13/16" of thickness, in total, for both sides of the wood paneling which is surprisingly sturdy and holds sound quite well.
I searched the DIY site before typing this all out and couldn't find the exact scenario, so I am hoping that a few kind users could offer me advice on how I could make this mount work, given the layout of the room, having no other mounting options (except for maybe a floor standing mount).
So if there is a reasonable way for a DIY novice like myself to safely install the TV with minimal damage to the wall, then I am all ears and would be so appreciative.
The wall plate hardware includes are 4 lag bolts with washers, and concrete anchors. The directions say to drill 3 inch pilot holes into studs which have no less than a total depth of 3 1/2 inch, with a 3/16" bit.
Pictures are attached. LMK if you need anymore info to help.
