Has anyone seen this type of bracket before, or have suggestions on what it might be called? The drawing is upside down for the intended usage - basically I want the U-shaped piece on the underside of a joist, and the other piece on the top of a sheet of plywood. My goal is to slide if together to hold the plywood up.
Right now the whole idea is hypothetical - first I need to find the bracket to see what kind of load it could hold.
  • Looks like a TV-wall mounting bracket. – Ben Welborn Apr 19 '16 at 21:37
its called a z clip usually, but the socket side is a little different
| improve this answer | |
