I am installing an outdoor conduit that consists of four #8 AWG THHN wires inside gray 1" PVC. I need to hook it up to the main service panel and I am not sure what's the best way to do it.
I understand I can install an adapter that hooks the PVC pipe, or some other conduit, directly into a knockout in the panel. The problem is that the panel is not easily accessible without tearing down chunks of the wall on which it hangs (it's solid drywall behind the panel and stucco all around).
Or I could terminate the pipe at a conduit body near the panel, drill a 1" hole in the stucco, route the wires into the wall through the hole and somehow fish them out into the service panel through an available knockout. But then some section of the wire (maybe 6-12" long) would hang inside the wall without any conduit around it.
Is that acceptable by the code or do I need a continuous conduit all the way to the panel?
