Well, two years ago I painted my deck railing and now it looks like this.
enter image description here (Peeling and flaking off)
My instinct is to sand it down with a random-orbital sander and then a wire brush and repaint, but I suspect this won't be good enough. How do I paint over this to make it last?
  • Did you prime it? Did you use an outdoor-rated paint?
    – iLikeDirt
    Apr 17, 2016 at 15:49
    Yes, the paint was high quality indoor-outdoor paint. I did not prime; I thought that paint itself was a good primer on bare wood. I did three coats. Was that a mistake? Apr 17, 2016 at 16:14
Scrape, sand, prime and then paint with exterior grade products. Longevity of the paint will also be based on the moisture content of the wood at the time you painted it. A handy 'mini-Ligno' moisture meter is used to determine if the wood is dry enough to hold primer and paint. Consult with the paint manufacturer for moisture content recommendations.
See... Mini-Ligno http://www.lignomatusa.com/meters/mini-ligno-md/ Long lasting paint... http://www.paintpro.net/Articles/PP503/PP503_CoatingsFailure.cfm
  • Are you saying "scrape and sand" down to nothing? In other words, start over? Apr 17, 2016 at 16:15
  • No. You need to remove debris from years of use and any loose paint. Then prime and paint. This link may best suit you by Benjamin Moore paints... benjaminmoore.com/en-us/for-your-home/exterior-painting
    – Been There
    Apr 17, 2016 at 17:46
  • ok, so paint that looks good, I should just prime and re-paint? Apr 18, 2016 at 3:23
  • What I mean to ask is: do I prime and paint over the remaining paint, or do I paint without primer there? Jun 30, 2016 at 0:14
  • I wish I understood this better. I did all this two years ago and now it's back to peeling just like the photos above. Jun 22, 2018 at 20:20
I used Sherwin Williams exterior deck and floor enamel on our front porch..I primed it first with a water based spar varnish..It has been four years and it has not peeled..I used to have to repaint it every year..
