So, I was cleaning under the kitchen sink and noticed there is a switch under there! It isn't clearly marked what it's for, I tried playing around with it and the garbage disposal thinking maybe it was a maintenance safety, but it didn't seem to have an effect.
I was just curious, is there a common reason for switches to be placed under the sink?
    I've seen the switch to operate the garbage disposal under the sink. If it's not for that, than maybe a dishwasher disconnect? – Tester101 Apr 15 '16 at 12:36
A standard snap switch can be used as a safety disconnect for small hard-wired equipment.
I would suspect it is a disconnect for the dishwasher.
Good luck!
|improve this answer|||||
A garbage disposal switch, toe kick lights or under cabinet floor heater.
Maybe for a sink-specific water heater booster, beverage dispenser. Have you tried following the wire to see where it goes?
