I have replaced my kitchen counter top and sink, The new drain is in a different position. The drain down pipe does not run into the "p" trap at a straight vertical, no matter what I do with the other elbows and pipes it is just not able to connect properly and maintain a straight vertical. I am temporarily using a flex down pipe, its not at all a permanent solution. What can I do?
    You'll need to phrase something as a question in order to get an answer ...
    – brhans
    Apr 14 '16 at 14:38
  • Can you include a photo or two?
    – Tester101
    Apr 14 '16 at 14:54
  • I'll load a pic this evening.
    – GreggO
    Apr 14 '16 at 15:20
  • Sorry for the pics 90" degree offset, was upright prior to the upload.
    – GreggO
    Apr 19 '16 at 14:11
Sounds like you need to install a new P-trap. Cut it off past the trap and then re-plumb in the correct spot. You may be able to use the old P-trap depending on where you need to cut, how it's glued, etc, but without a picture that's impossible to judge.
Be sure when you cut it that you'll be able to get a new fitting on the end, that usually means at least 3/4" pipe sticking out into the cabinet space.
Dry fit the entire assembly first, including the tailpiece to the sink, and only glue it once it's all in place.
There are P-traps with unions on one end that can help if the fit is tight, and regular unions (or slipnuts) are also sometimes necessary.
  • If I could bend my own an inch larger in diameter that would end this saga.
    – GreggO
    Apr 19 '16 at 14:14
  • I've considered using two elbows with a straight to join them at the correct length but I would only do that if I could find those fittings in a glue-able form, Home Depot only carry's compression nut type.
    – GreggO
    Apr 19 '16 at 14:19
  • @GreggO - In all of the Home Depots I've been to, the glue-able fittings are usually with the 10' lengths of pipe 1 or 2 aisles down from the aisle where the P-traps with compression fittings are.
    – brhans
    Apr 19 '16 at 20:40
