My house sits on a slab that is currently not level. Given that I have plans to correct the foundation issues in about 1.5-2 years, does it make sense to install the cabinets so that they are squared up against the floor (with the countertop as parallel as possible with the floor - presumably I would still re-shim as best I could following the slab corrections)? Or should I still stick to keeping things as level as possible?
Also, aside from the obvious, what would the consequences be of not keeping them level?
Update: Thes severity of the slope has the bubble on my level almost touching one of the vial markers. So it's not perfectly centered, but is still between them. I'm not sure if that means anything (or if there is any kind of standard that dictates vial parameters like those limit markers - otherwise what's just inside on my level might be different on another level).
