I have a 6500 watt predator generator, here lately every time I run it, after it runs for maybe 20 minutes to 1 hour the lights in our home cut out and then back in.
At first it was only doing it for a few seconds, but now when they cut out they stay out a few minutes before cutting back on.
How can I fix this?
    Could the inverter be overheating? You might want to clean out any air flow ports it has. – Dan D. Apr 10 '16 at 11:07
  • I agree sounds like a heat issue, is it 6500w continuous or peak and what is the total load would be my follow up question – Ed Beal Apr 10 '16 at 11:13
  • Is it still under warranty? Take it back to horror fright. (And if your needs are mission critical enough, consider a different unit.) – Aloysius Defenestrate Apr 10 '16 at 16:08
