I am running a septic line from my mancave to the main 4" sewer line coming out of my house.
I want to splice into this line coming out of the house.
The total run is 60'; is this ok to do?
closed as unclear what you're asking by isherwood, Tester101 Apr 11 '16 at 12:15
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • Hello, and welcome to Stack Exchange. A diagram of what you're planning would be helpful. Including altitudes would also help, so that we could think about slopes (which is important for sewage flow). – Daniel Griscom Apr 10 '16 at 14:42
  • the grade is level from mancave to septic line, 60'. – Charlie Downey Apr 10 '16 at 17:08
Only if you can get the required slope on the line.
Waste lines larger than 2" are required to drop 1/4" for every 12" of run. So, this line must drop 1 1/2" for every 10 feet or 9" for 60 feet overall.
Can you get that much vertical drop in you line?
If not, you are asking for a clogged line and backed up toilet and nobody likes that. 😞
Good luck!
