Does it hurt if I use pipe dope on water lines connecting a faucet in a vanity?
  • While is does not address the "safe" aspect, the following Q/A point out many relevant points on dope and when it is appropriate: diy.stackexchange.com/questions/21117/…. I personally know of no reason why pipe dope can't be used for a vanity - but I've only used tape or just relied of the fittings without. – Evil Closet Monkey Apr 6 '16 at 22:04
  • Pipe dope is for lubrication, rather than sealing, but here's one hypothetical drawback: pipe dope could conseal a flaw in the connection. It would be better to know that the connection was poor before finding out by having the pipe dope fail a week later. With a finely threaded connection I think that the sealing capacity could become prominent, leading to the possibility of a cover-up. – Ben Welborn Apr 7 '16 at 17:19
no - pipe dope can pretty much be used everywhere. its not necessary though on anything but a thread to thread seal. most vanities nowadays use flexible supply lines that have compression type fittings at either end with a rubber seal in them. its not necessary on that connection at all.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
