I have a faucet similar to this one:
Unfortunately, the pipes were not secured very well behind the enclosure, which I assume is a common problem. Specifically, the valve is not mounted to a cross stud, in fact, there is no cross stud like the one shown below:
Because of this, the pipes are free too move a bit. I have two questions:
  1. I am not sure how much to turn the housing screws that pull the large circular cover as with every turn the valve and pipes pull closer to the enclosure. I am thinking that I tighten them up just past contact, plus a few rotations, and use some thread locking fluid. They have been backing out a bit as the year goes on. Thoughts?
  2. There is a foam/rubber seal behind the cover that is close the outside edge. This prevent water from running down the wall and getting behind the enclosure. Do I need to worry about water getting behind the metal sleeve, shown in the first photo? There seals look like this:
But I am wondering if I need an o-ring like this:
I may answered my own question but it would be good to hear others' thoughts or confirmation, plus it may help others in the future seeking advice.
  • O rings need some pressure to seal. Since you will be pulling on the plumbing I would put some calking and then pull the cover snug.
    Apr 3 '16 at 23:23
    I’m voting to close this question because it's been abandoned.
    Dec 23 '20 at 20:38
you have sort of answered your own question - let me elaborate
1) the valve body should be secured somehow to avoid fore and aft movement. the movement flexes pipes and joints that arent meant to be flexed, and it is this movment that keeps unscrewing the trim face screws. you can simply cut a hole on the rear wall the valve is within, and place a mounting block in there. then cover the hole with a pop in cover or patch the wall outright. if you have no access, then unfortunately, this means the valve is only held to the front abs sheet by compression between the rough in plate and the trim escutcheon. i would switch the screws to socket head pan screws if you are going to use threadlocker, and only use removeable strength locker. otherwise, you may have a hard time removing the stock philips head screws down the road.
2) the two foam seals are very important as they prevent water ingress behind the escutcheon plate. if they are worn, you can get replacements from some companies (moen has them) but you can just make your own from adhesive foam weatherstripping. make sure you leave the gap in the outer one and make sure you orient it to the bottom (it acts as a wicking hole). when you reassemble everything, put a small bead of silicone around the point where the escutcheon meets the shower liner, and where the escutcheon sleeves the valve shaft cover. just make sure you leave a small gap at the bottom to allow for wicking.
3) the o ring to me doesnt seem to serve any purpose other than to act as a circumferential spacer to retain the decorative cover. or it could be assembled incorrectly originally, or its a feature in a valve i am unfamiliar with.
hope that helps
  • I don't think the faucet has the o-ring anymore. I guess sealing it should work for a temporary fix until I remodel the bathroom and shower. The bolts are slotted, and I think I have some light duty thread lock. Thanks for the thoughts.
    – Evil Elf
    Apr 4 '16 at 16:17
  • thats really weird - the screw heads look absolutely like philips heads in the photo. and if the faucet doesnt have the o ring anymore, how is it in your photo? Apr 4 '16 at 16:41
  • Those are just photos from the Web.
    – Evil Elf
    Apr 4 '16 at 21:59
