I just bought a new house that was winterized and vacant for about 6 months. It has a deep well with a jet pump. When I turn the pump on, the tank does not fill up but water does come out of the taps. The pressure doesn't go over about 40 kpa and the pump never shuts off. I've been keeping the pump turned off unless I actually need water.
I had a plumber look at it and he said it was probably something obstructing the jet in the well, but he won't be able to come back to work on it for several days. Is his diagnosis accurate? Is this something I could do myself? I couldn't find any instructions for pulling a jet out of a well online.
