I recently purchased an Orbit Model # 57894, and I'm trying to use it with these Rainbird Valves.
I've got it all setup and connected, however it won't turn on the sprinklers on schedule or on manual mode. Are these valves incompatible with this timer?
Both the Timer and the Valves are designed for 24 VAC operation which is the standard voltage for sprinkler equipment so they should be compatible. You need to check with a voltmeter that the Timer is outputting the proper voltage and that it is present at the valves.
