I would like to make a 10' x 16' shed using concrete blocks for the base. Should I put sand or cement under the blocks?
  • We could provide better answers if you let us know where you live. Different regions will have different concerns.
    – ench
    Mar 31, 2016 at 18:35
Get Local Building Dept. approval, they'll direct you on this as well. But, 4" of tamped sand only works if it's retained, it washes away. Tamped 3/4" jagged gravel at 4" deep is the best choice. The bigger issue is tying the building down from wind loft. This is where a concrete filled cinderblock & poured concrete foundation may be required. Don't mess with the Town, they'll fine you $1000's & also make you tear it down regardless of how right it's built.
  • The poster doesn't mention where he lives, so he may not need Building Department approval. Where I live, one detached structure under 200sq ft doesn't require a permit.
    – ench
  • Thank you, it's 100s.f. around me. But, I also can't assume she's free & clear. Plus, the Building Dept. will still give their guidance. And, of course, I'll give more if she needs it.
    – Iggy
    Mar 31, 2016 at 22:20
  • Sounds like you've got a better building department than I do. Mine doesn't really advise, they just ask you to pay and submit, and they'll tell you why its a bad idea after they get a few hundred bucks.
    – ench
    Mar 31, 2016 at 22:53
    Yeah, that's mine too :) But, they're cheaper than a contractor & they're the ones you want to look worshipful of. Power trippers love anyone who comes groveling to them.
    – Iggy
    Mar 31, 2016 at 23:02
I agree with Iggy,having put up a shed myself. Foundations are of particular importance to building authorities, especially if you are in a high wind geographical location. At a minimum,I'd be digging trenches the perimeter of your shed, pour concrete as a foundation to lay a couple of courses of your concrete blocks The blocks should be of the type that have holes through the centers. Once laid, use threaded steel rods,running through the blocks vertically and fill all blocks with concrete. This will provide anchoring points(threaded rods) to tie down your shed. The area within the perimeter could then be filled with a good base material,compacted well, even mix some of your dry cement with it. This will form a good base if you decide to lay concrete later. Above all,consult your authorizing body before commencing anything.
