I hope someone can help me resolve this frustrating situation.
My lawnmower (Briggs & Stratton Max engine) is not starting and it has had problems starting/staying on before this. I followed others' advice to clean the carburetor and change the spark plug, but it is still not starting. Now, I notice gas is leaking from the carburetor cup around the rubber gasket area opposite the bolt. The cup does not feel snug and has some wiggle room which makes sense why it's leaking, but as I put it back together the way I disassembled it, I cannot figure out what the problem is. I have tried reseating the gasket and tightening the bolt several times but each time once I open the fuel line the cup begins to leak again from that same spot.
So now I have a bigger problem that needs to be resolved first, but:
- What is the problem and how do I fix the leak?
- How to I get the engine running again? The new spark plug supposedly comes pre-gapped to the specification my mower requires so I'm not sure if that is the issue. The gas in the tank is anywhere from 1-6 months old. Oil level is good.
