I was drilling through the wall (above the radiator, but not above any pipes or sockets) and hit something metal. I have drilled a tiny hole in that metal plate. It's not copper, looks silver. What is this? Can't identify what it could be
Stop. You probably hit a metal plate protecting plumbing or wiring behind it. It's there specifically to prevent people like you from drilling through it and electrocuting yourself or causing a flood.
I recommend you stop whatever job you're doing and consult a professional, or at least a handyman.
I would first like to congratulate the others for giving good possibilities, but would like to add another: You hit a stud.
Depending on the size of your drill, it might just look like a plate, but its a little piece of architecture that you don't want to hit (mostly for your drill's sake.)
I suggest filling in the hole with Spackle, then drilling elsewhere nearby, but only after checking for another stud or metal piece.
This can be accomplished with a good strong magnet (sometimes,) but also with a mid-price handheld device called a stud-checker.
Happy drilling!
I'm glad you noticed & didn't go further. You'll need to drill a hand width away from that area. Of course, if possible find out what it is. If you can't get a visual from an attic or basement, then you can drill a bigger viewing hole away from it to confirm there are utilities being protected by the plate. Use a depth-stop on your drill...drill a hole through a thick block of wood so just enough drill bit is protruding. You'll then need to patch both holes.
All of the above responses seem to be spot-on for possibility. Building codes and then material usage in construction vary from region to region. If it is a protective metal plate (ie - a pipe for water,sewage, or electrical wiring is under this plate) it is a heavy and thick steel, and hard to accidentally punch through. (Unless you have professional type drill bits) I'm betting a steel stud.(Since you did not get a nice shower, trip a circuit breaker, or actually NEED to call a professional :) ) If you're drilling into a wall, maybe you want to hang or mount something on that wall. You would want to find that stud if your place was built with them( or remodeled with an extra wall or two...) It will grip a screw well enough to suspend your item. Use appropriate hardware to mount anything. Find out what that screw or mounting hardware(drywall anchor?) should be. Otherwise: If it took you a bit of effort to push your 'tiny' drillbit through that metal... try somewhere else on the wall. Get someone to look at it too, just in case. Better safe than sorry. Always good to ask someone who knows. Luck
Thank you all!
Think it's the alluminium stud - there are no electrical outlets or pipes anywhere around. It's an internal plasterboard wall. There is nothing on the otherside - just another room (no electrical outlets on that side either). Plus the depth of the new hole is only about 1 cm, logic suggests wires & pipes should be burried deeper than that. The drill bit I was using is for wood, not metal. So I don't think I would have been able to drill a tiny hole with it through a metal plate!
Great! As long as you confirmed there aren't any utilities, then drill away with confidence. But, don't hang anything over 70-lbs. or 32-kg from those metal studs, most especially not from a single stud. – Iggy Mar 27 '16 at 12:17
1Twice you have mentioned a belief that if there are no outlets nearby, there must not be any wires to worry about. As a general rule, that totally does not work. Some wires traverse long distances in the walls. For instance, a circuit which powers a far bedroom must get there somehow. The rule is, wires can be almost anywhere if there are guard plates, and even they are not required in many locations (e.g. If centered in a 2x4). There are other utilities too. Of course you know your house better than I. – Harper - Reinstate Monica Mar 27 '16 at 17:17
1"Plus the depth of the new hole is only about 1 cm, logic suggests wires & pipes should be burried deeper than that." Note that this is exactly why plates are required on wood studs in the first place, when a wire or pipe is close to the edge. You may have metal studs, but keep in mind maybe for your next place that as @WolfHarper said, wires and pipes are frequently run in places where there is no outlet, light, sink, or whatever around. There's no way to know where wires and pipes are unless you can see them; don't assume. – DrewJordan Apr 1 '16 at 15:29
You might look on the other side of the wall to see if there's something electrical that has a metal box around all except possibly the front part. For example, an electrical outlet, an electrical switch, or a circuit breaker panel.
Also, check for a heating/air conditioning vent, both on the other side and from above and below. Those use thinner metal than is used for electrical equipment.
air vents are all in the ceilings in this flat. Heating - not sure, but the radiotor is a water one, so if it was that - should be flooded by now. – penny2016 Mar 27 '16 at 9:25
The air vents in the ceiling ONLY exclude vent ducts if the equipment heating or cooling the air are also in the ceiling. I assume that you've also counted the place where the used air is collected as an air duct. – user6030 Mar 28 '16 at 3:23
