first time bath floor tiling. The subfloor is gypcrete concrete but around the toilet it is wood. The wood is rotting so I think I will take it out. But I don't know how to proceed. So a couple of questions:
How do I know if this is not part of a bigger structure? The rotten wood can be taken out easily but the good part stick very well to the floor.
What tool can a DIY-er find to remove this without damaging the plumbing?
After removal, what should I do to repair that part of the whole floor for tiling.
If another wood piece, how do I cut and put it down? after that I imagine I will need to put in a backerboard for that portion?
Is there anything similar to concrete that can be used in this case? wood part
EDIT: I found out that the subfloor is not concrete, but gypcrete. Oh my amateur. And I have also decided that I will hire someone to do it as I don't have the right tools and skills and time so between running around renting tools and spending time and risking doing things wrong I have decided will have to hire someone. Thanks God I didn't start working on the 2nd bathroom.
EDIT 2: More questions :/
1. Do I have to remove the vanity cabinet? I don't want to. One contractor says I need to, others don't.
2. I am given 2 options: leveler or backer/cement board.
2a. Do I have to remove the old thinset completely if I go with leveler?
2b. Can leveler be used on the wood part? I didn't know that
2c. Which option is easier if in the future I decide to replace the tile, bathtub, toilet wood subfloor, vanity cabinet or toilet?
I am more inclined to use the leveler. One contractor says I need to use Wonderboard, another says I have 2 options here. But if the thing is poured over the wood and stick to the bathtub and the cabinet, won't it be very hard to remove it in the future?
EDIT 3: I removed the flange. I poked a measuring tape into the gape and the wood is 2 inch thick and below it is 2 feet of empty space. I don't understand how this piece of wood is secured in place. How do I removed the wood without damaging the gypcrete or below structure?
removed flange
I can only borrow this circular saw https://www.ryobitools.com/products/details/561
You've got a sticky wicket of a situation. However, being able to remove the pipe flange was a great benefit. You'll need to build-out the joist under the wall with layers of 2x6 scraps until the scraps protrude at least 3/4" beyond the wall plane for good support of the new subfloor & the ability to screw or nail.
To cut out the old subfloor, lay a bridge of plywood over the wood area, from Gypcrete to Gypcrete. Drill holes in the wood area, inside of the joist, to poke a tape measure down. Then, set your circular saw's blade depth to the measurement from the bridge's top & down to the bottom of the subfloor.
Then, you'll want to remove the nails & cut 3/4" over or on top of the joists (likely a line where the old nails were), so the new subfloor can rest on half of the old joist. Once the wood floor's out, you can use it as a template for a drop-in plywood replacement. You can do cement or cement board on top of the new subfloor patch.
10
  • That looks like a good way to go. I would use 1-1/4 plywood and pour the cement to get it level with the surrounding floor
    Mar 26, 2016 at 14:36
  • Thanks. He lucked out better than I ever did. I always just get 1 open access joist.
    – Iggy
    Mar 26, 2016 at 14:46
  • Thanks guys, I edited my questions as the situation has changed. Could you explain more regarding the cement leveling idea?
    – Motoko
    Apr 5, 2016 at 4:16
    1- If there's tile under the vanity & you're not removing those, then you can leave the vanity. If there's no tile under the vanity, then for water damage protection, it would be best to remove the vanity & tile beneath it. 2- Yes, get the old Thin-set down as much as possible, but it doesn't need to be fully removed. Tall ridges will mean that new Thin-set won't fit in & that the tiles may not level or flatten as needed. Yes, cement-board, cement & leveler can all go over wood. But, cement would be best for bulk filling (no open seams) before applying leveler. Your best future option.
    – Iggy
    Apr 5, 2016 at 14:02
  • So I plan to use Henry 336 for primer and Henry 547 for patching/skimcoat, both for the gypcrete and the plywood. Do I need cement board on top of this patch or applying thinset directly now is fine?
    – Motoko
    Apr 6, 2016 at 3:20
