Do I need a permit to change old outlets out that are cracked or not working and replace them with new ones Thanks
    For code questions you really need to enter your location, at least down to the city.
    – JPhi1618
    Mar 23, 2016 at 20:51
    Our municipality requires a permit for any repairs exceeding $50.
    – ArchonOSX
    Mar 23, 2016 at 21:26
  • So a 2$ outlet or if you put a hospital grade outlet in at 18$ the answer is No.
    Mar 24, 2016 at 0:34
  • You need to mention where you are from. In the UK, you need a certification to replace an outlet. In Germany you don't.
    – texnic
    Mar 24, 2016 at 16:22
You do not need a permit to replace fixtures or devices (outlets) with new ones.
  • I agree. Replacing fixtures and devices falls under general maintenance and typically does not require inspection.
    – Kris
    Mar 24, 2016 at 0:11
It's not likely that a permit would be required, but the only way to know for sure is to contact your local building department.
