Symptoms:
- Location is suburban Long Beach, CA. 5 miles from the beach.
- I started getting bit two weeks ago. I've got 12+ bites. They're very itchy red welts up to 1/2".
- The house has three broken foundation screens. For rodents to get in. I've never seen rats in the area.
- For 1 month I've occasionally heard banging type noises in the walls around my bedroom and the bathroom. It doesn't sound particularly like animals.
- The attic fans are screened. There aren't eaves on the house. Walking around the house, there's no sign of birds. I haven't seen or heard anything in the attic.
- It took 2 weeks of getting bit and looking before I found any mites.
- When empty, they look like a single piece of small translucent dust. Practically impossible to see unless crawling on a black surface and viewed within a foot with bright light and 20/20 vision. When full of blood, they're much easier to see. They look like black dots and can be seen when crawling. They're very slow, dumb, and clumsy. If you shake your shirt that will probably flick them off. They're difficult to crush (like fleas) when empty, but easy when full. If you're paying attention, you may be able to feel one crawling on you. In my case, they're attracted most to groin (underwear), feet/ankles (socks), armpits, and back of the knee. Biting mites like warm pockets of skin or where clothing fits tightly.
I found ~12 mites crawling around a crack where the wall meets the floor in the bathroom.
Several months ago I noticed a minor ant problem around the same crack. That crack is the only location in the house that I've identified as an insect source. The house is pretty clean and not much insects until recently.
In total, I've seen ~25 mites. All but one were in the bathroom. The other I felt crawling on my arm when I was lying on my bedroom floor.
My mom also started getting bites roughly at the same time as me. I found some carpet beetles around her bed area. Cleaned up the whole thing but the bites came back soon after.
Dad in the same bed as mom is not getting bit. Sister in the next room to me is not getting bit.
The wall is a separator between two bathrooms. Depiction:
There's also an attic above and a crawl space below.
How should I control this rat mite or possibly bird mite infestation?
- What form of pesticide if any would do well?
- Seal the crack with caulk?
- How to determine what is going on behind that wall? And find the animal.
- Fix broken foundation screens around home.
- Add screens to air vent openings.
