The wall contains metal studs 24 inch apart. On a previous TV, I installed an articulating TV mount (80lbs total with mount) on two metal studs with 4 snap toggles (that's 2 snap toggles per metal stud) The snap toggles are suppose to support up to 80lbs each. So i'm guessing with 4 snap toggles that equates to 4 x 80 = 320lbs distributed among two metal studs. However, my TV and mount is only 80lbs, so I thought that would be fine and haven't had any issues yet.
The question is:
- I haven't really used the articulating full motion aspect of the mount yet. It seems pretty sturdy, but I've never dealt with metal stud before as support. Should I be afraid that If i move it around that it could rip out of the wall?
So I have another TV that I need to mount. With the dimensions of the room, it looks like I can only use one metal stud. The TV is also lighter, so with the mount it'll be around 70lbs for a 43 inch LCD and the mount will be an articulating (ex. http://www.amazon.com/VideoSecu-ML531BE-Monitor-Articulating-Extension/dp/B000WYVBR0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1458420321&sr=1-1) which is meant to be mounted only on one stud as well.
The question is:
- Can I mount the TV (70lbs) attached to one metal stud with two snap toggles rated at 80lbs each?
Any advice appreciated! Thanks, D
