I just moved into a new house and doing my research, learning and planning before hanging a mount for a 40lb TV.
I have a Mantel Mount, which is basically a lowering mount to be hung over the fireplace.
I found out today that the studs are positioned in a way I haven't seen before. Its double studs and the narrower side is towards the wall, where I have to drill. Below is a photo, I tried my best to zoom into the area and highlight the studs, but I'll be happy to answer any question and describe them better if there's a need. (questions after the photo)
How do I properly drill into this for hanging such a heavy thing? Should I aim for the center, right were both studs stick with each other? Or is there a known trick for such type of stud arrangement?
