We have a projector screen that can easily be lowered or raised electronically, whose top support is 113" wide, and whose physical edges are each 3 and half inches inset from the sides, so the screen itself is actually 106 inches across. The screen requires fastening at the back to something sturdy at the extreme ends of the 113" long support, and I was hoping to hang it from the valence immediately in front of our balcony window, the valence being 114 inches wide. On the left side of the valence is a fireplace, however, and positioned at a 45 degree angle it has a beautiful mantle that is about 5 feet up but whose corner extends about 8 inches into the area underneath the front of the valence. The living area extends into another room on the right of the valence. If the screen is center mounted directly on the valence, however, then it can only be lowered about halfway before it hits the fireplace mantle, failing to clear the mantle by only about four inches. The living area extends into another room on the right of the valence.
We have, as I see it, two options other than tossing the projector screen idea entirely.
The first option is to buy a 2x4 the width of the screen, and attach it to the valence so that it is offset slightly to the right. Because the 2x4 would be positioning the screen an inch an a half from the valence, we would only need to push the screen two and a half inches to the right. This would extend the screen into the adjacent room on the right but only by two and a half inches athough The screen itself sound still be entirely in the room. It would not be centred on the valence however, and with its top extending into the next room, I fear that would look peculiar.
The other solution involves securing a 2x4 to the ceiling instead of the valence and having the screen pushed away from the valence by about 4 inches so that it can be centered on the valence, and mounted onto the side of the 2x4. However, because the screen needs a minimum vertical clearance above its mounting points of about 3 inches this would require additional space between the 2x4 and the ceiling, making attachment nontrivial. I am concerned if I attempt this myself, it will also look bad, but I also fear that I would not be able to afford the services of a professional that could make it look nice. In fact, I don't even know where to begin to inquire for such services or anyone that might know.
Obviously, I would like to minimize my costs, but I desperately need some advice from somebody with a bit of experience in home improvement.
I can take some pictures later tonight if it will help, but I hope that I have described the situation accurately enoug that at least a general idea has been conveyed.
  • Are the mounting holes for the screen through the back of the support, the top of the support or both? Are there mounting holes in the center area or only at the ends? How much does the screen weigh?
    – bib
    Mar 16, 2016 at 16:45
  • The mounting holes are at the back of the support and are only at the extreme ends. I further need a minimum vertical clearance above the mounting points of about three inches to accommodate the electronics that attach to it to raise and lower the screen. The screen weighs about 30 pounds.
    – Mark
    Mar 16, 2016 at 16:47
Projector Hanging
Definitely go with the ceiling mounting. However, I prefer simple, clean & neat.
(1) Is the setup I prefer. The top hook (4) is best, as it screws into the structure's framing, if you can find it. If not, then (5) can be screwed into the drywall or plaster to receive (4). (2) & (3) also use just the drywall or plaster & give you positioning flexibility. (6) can be an open or closed (carabiner) S-hook or even just a nut & bolt with washers, so just the top of the chain is removable.
  • Awesome idea.. The pic #1 helps immensely with the visualization and I believe it will work perfectly! It's far less awkward than dealing with a board, which was the only solution that I could think of. Thank you for thinking outside of the box and seeing a perfectly workable solution!
    – Mark
    Mar 17, 2016 at 1:15
  • No problem at all & thank you for asking to help many others. It'll be almost like hanging a picture.
    – Iggy
    Mar 17, 2016 at 1:18
  • Actually, I have one more question: what would be the best way to fine tune the leveling of the screen with this approach? Using chain I can only change each side by a whole chain link, and although my ceiling is level, I am not confident I will be able to get the left and right hooks sticking out of the ceiling at exactly the same height, so there could be a difference there that might be noticeable. Smaller chain links would offset this, but smaller chain links are generally not capable of supporting as much weight, and I would be most comfortable with chain that could hold at least 30 lbs.
    – Mark
    Mar 18, 2016 at 3:21
  • No problem, as many questions as you have. Only (4) or (4) with (5) would be a possible problem, but as long as you tape or ruler measure the hook's protrusion from the ceiling it shouldn't be an issue. The (6)'s can be hammered to tweak them. The chains, big loops or small, are where you would make tiny adjustments, treating multiple or all links. I prefer a 3 or 4 big loop look on each side. Squeeze the top & bottom of the loop with pliers, to shorten. And, squeeze the loop sides inward, to lengthen. You'll just be after a measured even gap between the ceiling & screen rail.
    – Iggy
    Mar 18, 2016 at 3:59
It sounds like a 2x4 (which is only 3.5" deep) will not be deep enough to give you something solid to grab through the back of the mounting if you need to lower it by 3".
Consider something like this
mount
A 2x6 can be attached to the ceiling using right angle brackets lined up with the joists. I would use at least four on each side. Alternatively you could use an angle iron (probably aluminum) that ran the length of the 2x6 if you think that looks better. Then mount the screen to the 2x6. For additional support, you could add angle brackets to the back of the screen mount through the bottom edge of the 2x6.
  • That could probably work.... do you know of anything that could generally be used to conceal the angle brackets? Because unconcealed angle brackets tend to be a bit ugly IMO... and industrial-looking.
    – Mark
    Mar 16, 2016 at 19:30
  • If you used angle iron (a long aluminum strip with drilled holes), after installation you could use fabric to cover the metal and extend down the face of the 2x6. This could be left as is (if you like it) or could be painted.
    – bib
    Mar 16, 2016 at 20:42
usually, these powered screens have an attachment bracket on the two ends, and nothing midspan. the power cord usually comes out of the one side close to the bracket but not through the bracket. the simplest solution would be to ceiling mount it and just get two offset spacers made. these would be simple wood or plastic blocks (any plastic fabricator should be able to make either, a carpentry shop could do both if they are comfortable with plastic). they are built so that you mount the block to the ceiling with screws, anchors, whatever. then the screen is mounted to the blocks with machine screws (plastic is best as the threads can be tapped right into the plastic). you can make them whatever height you want to ensure the right standoff.
a note of caution. these screens typically use a little ac gear motor that rotates very slowly. it tends to cause resonance vibrations that are somewhat tuned to the screen so that the screen assembly damps the vibrations out. if you mount it in any way thats flimsy (like the above sketch) or doesnt use the mounts mounting holes properly, you can vibration that can make a huge vibration in the assembly. its usually worse in anything over 100", and you can wiggle your mounts loose or cause premature wear.
its best to mount solidly to the ceiling with the standoffs and the original brackets.
  • The mounting holes for the screen are at the top back, so it must be screwed into a vertical face. The electrical connection for the screen comes out of the top, near the side, but that connection is why I require a minimum clearance of about three inches above the screen to the ceiling. I am not sure what you mean by "offset spacers", exactly.
    – Mark
    Mar 16, 2016 at 20:43
