My hot and cold water mix in the shower lasts only about 2 minutes ,then the water goes cold ,would like to know the reason ,its only happening in my shower .
    if its just the shower, you may have a faulty thermostatic mixing valve. otherwise, more info is required – personal privacy advocate Mar 16 '16 at 3:18
There's an adjustable & replaceable valve behind your shower's handle(s). This likely needs to be replaced, since it won't just pop out of adjustment due to it not being mechanical, as in a broken spring or such. The quickest resolution is to call a Plumber to get everything back to proper operation tonight or tomorrow.
| improve this answer | |
