I live in a 5 story condo, on 2nd floor.
I wanted to remove this foyer (in picture labeled as ENTRY). I see joists running across the room, left to right in the picture. The structural engineer came out and said it seems to be load bearing. He calculated for the room to be too wide for joists to span from wall to kitchen wall, so the foyer must support them. However, he's confused as to what is holding up the joists past the foyer, into the room. (towards the balcony)
As you can see in the plans, only a few walls are designated as structural. I am no expert, but this seems too few. Is structural wall the same as load bearing ?
I am still trying to find actual structural plans and not architectural ones, but I wanted to ask the community and what people think.
Thank you for your time.
