My Makita MAC2400 has been serving great almost a decade now. Recently I started wondering about the volume of air it has intaken over the year and that it all went through the air filter, which I have never changed. So I opened the filter housing and it didn't look too terrible:
Is it necessary to replace this filter occasionally and does mine look overdue? Here is the compressor:
Also, how frequently should the oil be changed? Unlike most small compressors, this one is lubed for quieter operation.
Compressors do need to have the oil changed usually based on hours of operation. Since it has been 10 years I would change the oil. The filter is hard to see in the photo. I usually blow air on my filters to clean them if working in dusty areas, Sawdust blows out easily dirt tends to build up. Shine a light in the filter can you see the light on the other side? If no time to replace. Maybe you will get another 10 years but I would change the oil a bit more often.
