Wet system underfloor heating suppliers seem to insist on tiled floors. I want to use solid timber planks, which have a thermal resistance that stops heat passing through easily. With good insulation under the pipes, surely the only way heat can go is up and heat the wood floor. I am not worried about movement and will probably put down 9mm OSB or ply under the planks. It seems to me that the timber flooring will still act as a heat store. Comments please.
    Be careful nailing/stapling down hardwood flooring if you have underfloor heating. – Tester101 Mar 14 '16 at 17:47
  • Keep in mind that thermal resistance = thermal delay. The heat will eventually migrate into the room but the floor will delay that. Don't expect the temperature to change on a dime. You could have a wait between when you turn on the heat and when you feel it, and a wait between when you turn off the heat and when the heating stops. Also, wood doesn't transfer heat to the room nearly as efficiently as say a metal radiator. So your feet will feel toasty when walking on it while the room is still feeling cool. – fixer1234 May 20 '17 at 17:19
  • Wet system plus wood floor plus leak equals a ruined floor. – The Evil Greebo Aug 6 '18 at 13:09
I presume that "Wet System" means water filled tubing or piping. But oh yeah, wood is no problem & is extremely common, both nailed-down traditional floors & floating laminate floors. There's no steam or moisture being released & the floors don't heat to anything more than a hot summer day.
However, insulation is okay but you really just need a shiny space blanket type of radiant barrier (the shiny side of tin foil) to reflect most of the heat upward & not even consider nor attempt thermal loading. You'll be happier & more comfortable with a system that can heat up & cool down or just maintain a room's or building's temperature.
| improve this answer | |
I have used hydronic heating on several wood floors and they have lasted the same as over tile or embedded in concrete. I would insulate under the pipes because heat rises but you will be heating the crawl space more without insulation. The one thing I learned on my first house I did this was you don't want to have a big set back because it can take several hours for the heat to stabilize I found a setback of more than 10 degrees caused the flooring to squeak more even after the house had stabilized. If I left the temp constant at 72 degrees after several days there was no more squeeking. The first home I did this on had ceiling heat never made sense to me but electricity used to be dirt cheap in pet Pacific Northwest, I changed to a gas boiler and under floor and even having my heat at 72 100% of the time my total power & gas bill was cut by almost 70% and it felt warmer in the house with warm floors.
