Framing a basement. I have a an exterior door that is set in the poured foundation. I'm building my wall that runs parallel to foundation that has the existing door and is ~2-4" from the foundation. How do I frame this opening? Of particular concern, if I from perpendicular from the wall to the in-swing door, it would seem that I wouldn't be able to open the door more than 85-90 degrees.
Edit: added pictures for more clarity
Edit 2: Added diagram of proposed layout (minus solution)
