I bought 3 LED flat panel ceiling lights from Costco. 2 panels installed perfectly. One one panel, 3 toggle bolts are installed perfectly, but 1 toggle bolt is stuck and I cannot screw it into the ceiling with about 1/2 inch gap.
The toggle bolt seems to get loose and cannot grab the ceiling and I cannot screw it into the ceiling.
I am wondering what I should do? Unscrew it and try again? It took me a while to make the toggle bolt into the ceiling, so my intention is to get it done by keep trying.
Any suggestions?
Update: I can push the bolt all the way to ceiling, so it does not hit a frame.
