I need to pull up the floor tile in my kitchen. i've tried using a hammer and chisel and the tile pops up easily, but it's too slow. what power tool is the best and fastest to take up floor tile?
is there something with a spade that works well?
A rotary hammer with sds plus attachments will likely serve you best. These tools usually have three functions: hammer (with a chisel bit for your purpose), rotating hammer (for drilling through concrete), and drill. The tool plus the chisel attachment will run you about $300. I've found mine very useful for the odd jobs of removing tiles and drilling for anchors. They can be found widely at home improvement stores and online.
    Many places rent tools like this although you might have to purchase the bits. After using this tool you can rent a rotary grinder with carbide teeth to take off the remaining thin-set mortar.
    – ArchonOSX
    Mar 6 '16 at 21:37
  • I've rented such a hammer at Home Depot for a day. Worked well to remove stuborn tile on concrete in a bathroom. Did not have to buy the bit/chisel. Worth the money.
    – DaveM
    Aug 13 '17 at 20:13
we actually use a pair of shingle removers. just shove under the tile, pry down and up pops the tile. easier on the knees and back than a hammer. two guys can rip out a kitchen floor in about an hour - even if there is lath under the floor.
http://www.roofersworld.com/red-ripperreg.html#.Vty2I_krKUk
