I have a 3 way setup, with a Dimmer Switch and a simple switch. I want to replace the Dimmer Switch with a timer switch.
The dimmer switch I'm removing has 4 wires: Black (hot), Green (ground), and two red. One red looks like it's going to a black wire in the system (load?).
The new timer switch has 4 wires as well, Black(hot), Green(ground), Red(labeled Load) and White (neutral).
How can I wire the new timer switch in place of the old dimmer switch.
House was just built last year. Thanks!
