I have a small, approximately 3x3' concrete landing in front of my basement door, from which stairs go up to the street level. I need to redo it and was wondering whether to tie the rebar from under the slab to bolt anchors I can set into the foundation footing of the house that it is attached to. I can think of reason pro and con both.
E.g. I think anchoring it would make it firmer combined with the building and resisting breakage from ground movements (e.g. nearby drainage) to a certain degree but at the same time, if it does exceed that point it might be better not to be tied to induce breakage along the contact line where the slab meets the building and not some other point (if my line of thinking is right, please correct me if wrong).
I was thinking to drill 3-4 anchor holes in the foundation using my hammer drill, set led anchors and drive some bolts, then tie the rebar from under the slab to it using chicken wire.
