I need to pour small stair entry into my basement, about 4 steps and it is narrow, with a brick retention wall on both sides. I was going to first evenly grade and pack the dirt, then put gravel, then pour concrete (framing and rebar aside). Does that seem like a good layering strategy? When I was pouring concrete indoors in my basement, I also used foam panel insulation and vapor barrier under wire mesh rebar and above gravel but those two parts I don't consider necessary because it is outdoors.
  • I always wonder if folks pack dirt well. I have a plate compactor and that will pack dirt ok. I usually used crushed quarry rock to level and it provides a good base that is easily packed. – Ed Beal Mar 4 '16 at 21:19
If you are building the stairs tight to the house, you need to go to the frost line with your concrete foundation. Run cinder block to just below the grade level, then go to the brick finish. If the stairs are small enough, just pour the concrete just below the grade and start your brick right from there. Many stairs have been built with a dirt infill then 4" of gravel over that, all on top of the footing slab. I feel that is an error in doing it that way since the dirt can take on moisture and freeze in winter. All gravel under the pour for the stairs, on top of the footing slab will keep heaving and cracking from freezing temps.
The plastic under the concrete also help slow the rate the water escapes the concrete, in essence keeping the concrete better hydrated, making it stronger. Foam panels will do nothing for it.
