I've recently had a frame installed by one of the local Ironworks companies (see attached pictures). This frame is made out of 1/4" steel is intended to hold horizontal 6" IPE wood boards with 1/4" spacing in between. My concern is the 10 feet section of the assembly shown in the picture. It's suspended about 1" from the tile and currently held in place by a few weld fillets against the railing in the back as shown in the picture. Occasionally, we get 100mph+ wind gusts in the area and I am worried whether this type and amount of welding is strong enough to resist such winds. Should I maybe ask the company to come back and weld more fillets? Thank you in advance.
10 feet frame section Fillet weld example
    With 1 bead on each side top and bottom it probably would hold up. I am not a professional welder but regularly have to build and repair framework to hold lighting and electrical equipment in a lumber mill (west coast). There are 4- 6 beads 1 inch or longer. I would think your 1/4" would bend in the center before the welds would break.
    Mar 2 '16 at 21:13
  • So you are questioning the work done by a professional iron works company? Have you asked them yet if they did a proper job? .... I'm with @EdBeal, it's FINE. Mar 2 '16 at 22:05
  • @EdBeal Thank you for the explanation. Appreciate it.
    – demisx
    Mar 3 '16 at 1:58
  • @SpeedyPetey I think I can easily guess their answer. I am looking for second opinions. And yes, I am questioning their work.
    – demisx
    Mar 3 '16 at 2:00
As long as the weld has made good penetration into the two metal surfaces you should be fine. From my experience the only way the weld would fail is through metal fatigue which involves a consistent flexing or bending of the metal. I don't see this happening (or it is highly unlikely) given that the steel posts (they appear to be C channel or columns) will be tied together by the horizontal IPE boards making it a rigid structure. You would probably get more failure to the welds from seismic movement than from sheer wind force.
