The plastic cap on my washing machine filter was stuck so I applied a little too much force when unscrewing it and its handle broke. Any idea what tools to use to remove it?
The washing machine is a Whilrpool AWE 4526.
Sign up to join this communityThe plastic cap on my washing machine filter was stuck so I applied a little too much force when unscrewing it and its handle broke. Any idea what tools to use to remove it?
Get a piece of pipe sized to fit into the center part and cut a slot in it with a hacksaw to fit the plastic where the handle was. Then you could use a pair of channel lock pliers to turn the pipe if you need to.
Good luck.
