I want to lay reclaimed pine floorboards over a newly laid concrete floor in a kitchen. Height from top of concrete to finished top of floorboards is 80mm. Boards are 20mm thick x 175 wide.
I could use 60mm battens screwed to the concrete. But I'd like to avoid this battening work by laying a floating floor consisting of 40 Celotex boarding, with 18mm plywood board on top and the nailing the floorboards to the ply-board. Can I use this construction? Advice please.
  • That sounds good to me the plywood would make an acceptable base to nail into for the pine.
    Mar 2, 2016 at 14:09
it does greatly depend on climate, but if this is a slab on grade or a basement slab, you will have issues with wood warpage and expansion cracking from water permeation through the slab, no matter how much of a vapour barrier you install. you will have to seal the slab with a urethane slab sealer first. then you can put in drycore or any other type of ventilated subfloor.
also, you may want to consider that reclaimed pine, although lovely, is one of the worst materials for a kitchen floor. its too soft and too porous for even sporadic exposure to water. its a terrible wear surface as well.
Thank you for not ruining nice new concrete. There's actually 2 approaches I would consider for the floating floor much better idea.
First is, to use battens (spare plywood strips or thinner plywood strips) to attach the plywood to each other & not have Celotex under those, vapor barrier yes but not Celotex...unless you can get thinner Celotex. Or, to use tongue & groove plywood to avoid battens altogether.
Second is, to use cement board since it won't warp or cup over time. These seams would just be taped & cemented or could just be left loose until & if a problem ever reveals itself. CB will also have the ability to crumble if expansion & contraction of the Pine battles it's confinement & it will.
I think the real benefit of large panel backing would be to pre-fabricate complete panels, if possible to handle for the room size. I'd build it upside down, would allow for sloppy or loose holes in the plywood for movement of Pine. Dry-lay the floor boards with good book matched or vein aligned or designed face down, with wax-paper strip spacers tucked under the good face (for removal later).
Slather on glue or even contact cement, drop on plywood or CB & screw through it & into the Pine, 25mm screws so future re-finishing can be performed at least twice. Edges of pre-fab panels would be overrun with Pine on one edge & run-short on the other edge to provide an overlap or under lap...same for ends depending on orientation & length of run.
Completed CB panels can be slid into place with short-run face painted with glue or can be edge glued. Plywood panels can be edge glued or glued to free batten edge & overrun underside.
