I want to relocate a GFCI outlet in my kitchen that is currently below my top cabinets to above the cabinets so I can plug in an LED rope light and illuminate above the cabinets. With that being said I wanted to connect a switch to the outlet so I can turn the light off and on.
When I took of the face plate for the outlet I noticed there are 2 sources of power (see pictures). There are two hot wires (black) and each are on their own brass screws. Then same thing for the neutrals but on the silver screws.
So do I have to install a 4 outlet box and put a power source to each of the outlets and then wire the switch to one of the outlets? Or can I put the two black wires together and put it on one brass screw and same for the neutrals?
Then is it a good idea to use a dimmer switch?
