I am from India where we use 220V AC supply. There are two power supplies for my house. Can I use the Live wire of one power supply A and the neutral wire of power supply B to power my geyser? I want power supply A to be billed
    Why not use the neutral from A? Without knowing the code in India and more about the setup it is difficult to say definitively, but in general, sharing neutrals can end quite badly. It may work fine for years, then cause a fire as soon as something goes wrong.
    – user4302
    Mar 1 '16 at 19:22
  • @Snowman Thanks. I am rewiring my home and am unable to locate the neutral of Supply A myself. I think I will take a professionals help Mar 1 '16 at 19:23
  • Good idea. I recommend reading this question and the search results here
    – user4302
    Mar 1 '16 at 19:27
This is a terrible idea, not only for a variety of safety reasons, but also because there is no guarantee both power supplies will be on the same phase.
For instance, I have seen a building with two separate 120/240 main panels, each fed by its own transformer from 480 volt 3 phase. They had been sloppy about mixing neutrals, for instance a fan circuit ran all over the factory, grabbing the nearest neutral wherever there was a fan, even if that neutral came out of a different panel. The two panels were originally on different phases of the 480 (for balance) but were later moved to the same phase - clearly they had been having problems.
A far bigger danger is it could overload the neutral wire (carrying its design load and also the unexpected load), and there would be absolutely nothing to detect this. Neutral wires do not have circuit breakers.
