I have a (Simpson Mercury) electric stove - and 2 of the 4 elements do not work properly. They heat up, but it is not possible to set the appropriate temperature for them - they are either on or off.
Does anyone know if I need to simply replace the elements or if there is a thermostat which needs to be replaced ?
