I'd like to hang a mirror on the wall. It's 4ft high and weighs about 50lb.
There are two hinges on either side of a metal frame.
The width of the mirror is exactly 32". I found that studs in the wall in question are indeed 16" apart.
I have two questions:
- What kind of bolt should I use? I'm guessing it must have a pretty large flange. Is it possible for the two hinges to be stowed away behind the mirror? Is it a good idea to look for a kind of bolt/contraption that keeps the hinges perpendicular to the mirror and slant the mirror slightly down? What kind of bolt would work for that?
- The studs in this area go down only from the ceiling to the middle of the wall, not to the floor. Should I worry that these are not suitable for a heavy object? I have no clue why my stud finder doesn't read anything from the middle of the wall down. The wall in question backs to the garage.
Update:
Here is the result. I used clamps and a 1/8" wire. A thinner wire would have provided sufficient tensile strength, but I was uncomfortable with producing crimping that will last. I opted for clamps instead. In any case, remember that during cleaning the mirror will take a bit of shaking, and so some extra strength in the wire and clamps will provide peace of mind.
