Is there a standard screw for tub overflow elbows? Or most popular? I am installing a new tub and looking for a overflow elbow with a screw pattern that will lend itself to a stylish overflow now, and replacement parts for when it gets rusty and grimy down the road.
I've included a picture of a one-screw overflow and two-screw that I have available to me.
Get the 2 hole one; it'll work for those, and single screw overflows almost always come with a bridging plate.
  • If you do not want to decide which faucet set to buy until later. I would go with Aloysius on this one. – ArchonOSX Apr 20 '16 at 8:38
I would use whichever fits the hole in the tub better. Note that the 2 hole elbow is a bit larger and may cover better.
-1
Actually, the only standard is what your bath faucet, knob, overflow & drain (maybe showerhead too, but who buys those they're always the worst clean out the warehouse afterthoughts) ensemble is. The manufacturer of whatever you buy should include its own overflow & drain. If you already have it & it doesn't have these for some reason, then either is fine & just depends on what's available at the store.
