I am looking to run a sub panel for a basement workshop approx 60 feet from the main panel, all inside. I have a table saw, jointer, band saw, planer, and dust vacuum, as well as routers and such. I was going to run a 60 amp breaker to a 100 amp sub with 6/3 cable. I wanted to run a higher breaker but then I am getting into much more money in the wiring.
My table saw draws 13 amps, and the planer draws 15. At some point down the road I plan on upgrading to larger tools, but for now they are more consumer grade.
In the panel I can run 3 20 amp breakers... lighting is actually run on another panel. Will 2 circuits be enough, or should I do 3? Any other ideas and recommendations are greatly appreciated!
