I am redoing some work in my bathroom. I have a hot wire running between two lights with the switch outside one of the lights. How do I wire it with 14-2 wire without running the power source to one of the lights first? I also must use this same power source for a fan where the hot goes into the fan and then down to the switch.
  • In case you "accidentally" type something in all caps, there are online converters that are here to help.
    – JPhi1618
    Commented Feb 25, 2016 at 18:33
They make products specifically for that problem. You wire hot, neutral and ground to every location (i.e. 14/2 wire) and the switch, lamp controller and fan controller uses digital signaling to send the on/off command over the 14/2 or wirelessly. Some can also be controlled by your smartphone etc.
