What sort of heating cable can be installed in the downspout and subsequent drain drain ? I was thinking of about 100 feet of drain that will be underground.
closed as off-topic by isherwood, BMitch Feb 25 '16 at 18:53
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – isherwood, BMitch
If this question can be reworded to fit the rules in the help center, please edit the question.
If it's a drain that actually drains you shouldn't ever need to heat it or melt anything. Well, unless you live in the Arctic or Antarctica. But, even in those places it's just a matter of getting the pipe under the frost line to be totally sure there's never a problem. Any kind of hot-wire would need to be replaced often & therefore would never be worth shorting the frost line.
